93 explorer with no heat
Old Nov 22, 2000 | 09:39 PM
garbz2's Avatar
garbz2
anyone have any ideas? truck warms up nicely gives heat for about 10 seconds then runs cold with the blower on. do the heater cores have blockage problems?
its 14 degrees and no heat.
Thanks Garbz
Old Nov 22, 2000 | 11:02 PM
PAUL_2's Avatar
PAUL_2
First off check the engine coolant quantity . Does the engine temp come up somewhere in the Normal range ? When was the last time the cooling system was serviced ? Any interior coolant leaks ? Its possible the heater core is clogged , but you need to also check to make sure the engine is warming the coolant to a temp where the interior will be warmed .
Old Nov 23, 2000 | 10:33 AM
PaulL1's Avatar
PaulL1
14 degrees and no heat??????????? Why dont you bring it to a repair facility and have the problem fixed. If you find out what the problem is are you really going to be able to fix it, when its 20 degrees below freezing?!
Old Nov 23, 2000 | 11:45 AM
garbz2's Avatar
garbz2
Guys i dont drive this truck the wife does. she has a bad habit of telling me of problems months after they occur. when they become critical. It comes up to tempature. The coolant is full
with new mix. i replaced the heads this summer when it started to use coolant. im leaning towards a blocked heater core. the hose to the core is very warm where the hose from the core is cold. i checked the routing of each hose and they are correct.
Thanks
garbz
Old Nov 23, 2000 | 12:02 PM
PAUL_2's Avatar
PAUL_2
Yes , If you have one warm hose & one cold then chances are the heater core is clogged . The good news is yours is pretty easy to replace .
Old Nov 27, 2000 | 10:02 PM
PAUL_2's Avatar
PAUL_2
garbz2
Jun 13, 2015 06:59 AM
garbz2
Jun 12, 2015 07:10 PM
garbz2
30
Mar 6, 2015 02:18 AM
craziejoker
Apr 16, 2014 06:10 PM
66rex
Sep 23, 2011 03:55 PM
