Sponsored by: Auxito
Park Brake Lines..
Old Aug 18, 2004 | 07:15 PM
smokinLUV's Avatar
smokinLUV
Park Brake Lines..
Well Im swapping my rear ends, and I can't seem to figure out how you get the park brake lines out of the brake housing on the rear end. Its nestled in there tight, and there a big spring and I can't see how it comes out of there. Does anybody know how you get them out of there? Thanks.
Old Aug 19, 2004 | 12:08 AM
Racerguy's Avatar
Racerguy
Disc or drum brakes?
Old Aug 19, 2004 | 10:09 AM
smokinLUV's Avatar
smokinLUV
Opps, sorry forgot to mention that they are drum brakes. 1998 F-150 2wd.
Old Aug 19, 2004 | 11:16 AM
Racerguy's Avatar
Racerguy
You'll probably have to remove the brake shoes so you can unhook the brake cable from the lever. Once the cable is off the lever then you have to squeeze in the metal "fingers" that hold the cable into the backing plate. You can use a screwdriver to push them in or maybe install a small hose clamp around the fingers to compress them or sometimes a 1/2" box end wrench will slide over the cable to do the same thing.
Old Aug 19, 2004 | 12:52 PM
smokinLUV's Avatar
smokinLUV
Alrighty, I will give it a try. Thanks!
