92 explorer door handle answer!
Old Dec 28, 2000 | 10:39 PM
corpsmen's Avatar
corpsmen
If your like me and you have a broken inside pull door handle for your 92 explorer, do not buy a new door panel. After calling the local dealers and getting the same answer 350 dollars. I decided to take matters into my own hands! What I did was this; First I bought a 5 cent zip cord, drilled a hole above and below the broken handle, pulled the zip cord so it latched inside the door panel and pulled it tight! I used a black zip cord to match the door handle and there you have it for 5 cents I fixed a 350 dollar problem. I thought it would be ugly but it looks good because it blends in well with the crease on the handle. I filled in the rest of the hole with apoxy and it is as strong as ever. I hope this helps someone else in the same situation. Any questions feel free to ask.
Old Dec 29, 2000 | 07:25 AM
christofer's Avatar
christofer
