need help please
Old Aug 18, 2004 | 03:01 PM
cotton54's Avatar
cotton54
Question need help please
I have a 1995 F150 crew cab pickup w/auto trans. I can not figure out what the problem is with it. the engine idles at 600 rpm when excelerating the engine runs rough to about 1300 rpm then smoothes out with no power loss. i have had a depletion in gas milage of about 1-2 miles per gallon,tail pipe is showing black with no excessive smoke, i have installed new wires, pluggs,distributor cap and rotor, o2 sensor, this pkup has 135,000 miles on it. It does not drink oil , when #2 plugg cyclinder was pulled it showed a brownish yellow plugg tip......please help . thank you
Old Aug 28, 2004 | 07:45 PM
bell47g2's Avatar
bell47g2
check the Throttle position sensor or air flow sensor.
