98 Explorer XLT - Turn Signal Problem
Old Dec 29, 2000 | 04:26 AM
jjan's Avatar
jjan
Just purchased a used 98 XLT w/ 52K miles.
Turn signals (both left and right) only works when steering wheel is in up-tilt position. When I lower the steering wheel tilt, turn signals will not flash/work. Any ideas how to remedy problem? Anyone with similar problems in 98 XLT? Thanks
Old Dec 29, 2000 | 10:35 PM
nitro94's Avatar
nitro94
I would remove the cover around the column and see if the plug for the multifunction switch might not be completely locked in place causing it to seperate when the column is tilted.
2000 XLT Flare Supercab Sport 5.4-Auto-355LS-Tow pkg-Bedrug-Xtang Tonneau
Old Dec 29, 2000 | 11:49 PM
markjoanie's Avatar
markjoanie
