Engine Reving after Computer Reset
Old Aug 18, 2004 | 09:51 AM
harrelsc's Avatar
harrelsc
98 Exp 4.6L Any clues out there that could explain what would cause the engine to rev up to 2000-2500 rpm then back to 1000 rpm then up again (repeats three or four times) after letting off the gas. This occurs only after reseting the computer ( pulling neg terminal 15min). It also only occurs when letting off the gas but not during acceleration or holding steady at any spped. The engine doesn't run rough during idle and accelerates normally but is sucking gas, went from 15mpg down to 10-12mpg. No codes being detected with generic code reader. Thanks
Old Aug 18, 2004 | 10:16 AM
saltzy's Avatar
saltzy
MIght this be the normal process of the computer calibrating itself after the "reboot"?
Old Aug 19, 2004 | 11:10 AM
buzzard's Avatar
buzzard
Yeah, they'll run a bit erratic for a few minutes.
