Sponsored by: Auxito
EGR Problems
Old Aug 18, 2004 | 08:37 AM
ryanjap33's Avatar
ryanjap33
EGR Problems
I have a 98 F150 5.4 engine and I just put Gibson headers on it. Since then it doesn't run right and the OBD II test said there was insufficient EGR. I replaced the EGR Tube and plenty of exhast flow is getting to the EGR Valve. I also find it funny that the EGR system worked fine until I put headers on. Any Ideas what might be causing this???
Old Aug 18, 2004 | 08:55 AM
banjopicker66's Avatar
banjopicker66
Have you checked the exhaust passages under the throttle body? They often become plugged, but they are easy to clean.
Old Aug 19, 2004 | 12:14 AM
Racerguy's Avatar
Racerguy
Was it a code P0401 that you got?
Usually that's caused by a bad DPFE sensor but like banjopicker said it could be the passages in the intake are plugged.
Any chance you missed hooking something up when you installed the headers? Maybe a vacuum hose or something?
Old Aug 19, 2004 | 07:34 AM
ryanjap33's Avatar
ryanjap33
got everything hooked up right, but it is still throwing the code, and yes it was the P0401 I will have to check the throttle body
Old Aug 19, 2004 | 07:51 AM
banjopicker66
If those passageways under the throttle body are clogged, cleaning them will usually restore proper operation. I made the mistake of replacing parts before I cleaned everything out. I guess it was worth it since I had 100K on the truck at the time, but it would have been nice not to spend hundreds of dollars on unneeded parts.
The deposits in mine were so hard I had to use a screwdriver and a hammer to get them loosened up.
I also used a .50 cal wire brush to get most of the rest out.
Good luck!
Old Aug 19, 2004 | 12:12 PM
ryanjap33's Avatar
ryanjap33
thank you, I will give that a shot this weekend
