trouble code 29, Vehicle Speed Sensor
Old Aug 18, 2004 | 07:43 AM
gaffmedic's Avatar
gaffmedic
I have a 1991 F150 4x4, with a 5.0L engine. The check engine light came the other day, when I checked the codes it showed 33 which is the EGR valve and 29 which is the vehicle speed sensor (VSS). Does anyone know what the VSS is and how I need to check, or where I can find any information on it.
Old Aug 18, 2004 | 02:21 PM
bigboytoys65's Avatar
bigboytoys65
The VSS (vehicle speed sensor) should be located on the back of your transmission on the top.
To remove it you need to unplug it, disconnect the speedometer cable from the speed sensor, remove the retaining bolt and remove the sensor, then remove the drive gear.
There probably is a way to check it...but I don't know about that.
Old Aug 18, 2004 | 02:39 PM
EPNCSU2006's Avatar
EPNCSU2006
Does your truck have cruise control? The VSS feeds the cruise first, then out of there to the engine computer. I'm not sure if this is the same between an 87 and your 91, but on my truck, there is a plug with a black wire and a green wire coming from the cruise control servo under the hood, that plugs into the wiring harness for the computer. I know Ford changed the way the wiring harnesses were routed in 89 or 90, so I'm not sure if this is still true for your truck or not. I'd at least look around the drivers side fender and see if anything is visually unplugged.
Old Aug 18, 2004 | 03:00 PM
gaffmedic's Avatar
gaffmedic
It does have cruise control, and I just had that fender well out before the check engine light came, I was replacing the parking brake cable. Thanks for the info
Old Aug 18, 2004 | 03:54 PM
Andyman8282's Avatar
Andyman8282
That would probably be the place to start, hope it works out for ya
Torky2
1978 - 1996 Big Bronco
31
Dec 19, 2024 09:01 PM
rterril02
25
Jun 4, 2020 08:44 PM
devriesj39
Jun 26, 2016 12:35 PM
rterril02
Mar 29, 2016 09:21 PM
1995droptopz
Jul 15, 2011 09:48 AM
