Sponsored by: Auxito
2000 4.6 won't start
Old Aug 18, 2004 | 07:18 AM
4x4user's Avatar
4x4user
Unhappy 2000 4.6 won't start
Help!!!!
I have a 2000 4.6 liter triton that won't start.... changed pcm,anti theft sensor and plugs. I have spark and fuel .. compression is good but oil pressure is questionable. have checked cam sensor,crank sensor,sending unit, cops......the engine is turning over sluggishly and doesn't seem to fire at all
any help would be greatly appreciated
4x4user
Old Aug 19, 2004 | 12:21 AM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
Low oil pressure shouldn't keep it from starting.
How many miles on your truck? Has it been well maintained? If not then it's possible that maybe a timing chain has jumped or something.
Does the Theft light or Check Engine light flash when you try to start it?
Have you checked actual fuel pressure?
Do the spark plugs get wet or stay dry?
Have you checked to see if the injectors are pulsing? You can use a 194 bulb with the terminals straightened out to do that. Stick a terminal into each connector on the injector and crank the engine while watching to see if the bulb blinks on and off.
knobcreek_60
1997 - 2003 F150
22
Aug 25, 2021 05:35 PM
angie-n-texas
2009 - 2014 F150
Oct 12, 2013 01:33 AM
lowrider57
Nov 19, 2012 03:07 PM
dgpach
Modular V8 (4.6L, 5.4L)
Mar 2, 2010 07:04 PM
goingnutz13072
Nov 28, 2006 08:17 AM
