AODE help
Old Aug 18, 2004 | 12:38 AM
68torino's Avatar
68torino
AODE help
My son has a CVic PI with AODE. he put in seals, torque converter and filter. has about 9 quarts of fluid in. It shows above the hatch lines but will not go into gear. Kinda almost wants to. He dropped one cooler line with it running and nothing came out. Torque converter was installed two clicks in. Torque converter had three quarts put in before install.
Ideas? Anyone run into something similar?
Old Aug 26, 2004 | 11:52 PM
68torino's Avatar
68torino
Guess not.............
Old Aug 27, 2004 | 05:47 AM
dbhr's Avatar
dbhr
From what I know on thes transmissions is that the converter needs to go three clicks to be fully seated, another way to tell is to make sure when the tranny is installed that the converter will move in the holes of the flywheel.
Old Aug 27, 2004 | 12:45 PM
68torino's Avatar
68torino
Thanks!!! I will have my son pull the shield and double check. I had wondered about it being fully seated, but I had only ever heard on torque converters to go two clicks. His is an aftermarket converter and he said he had to trim a little off the studs to keep them from dragging, which was caulked up to it being aftermarket. Our dumb.
