instrament cluster / ABS light sensor
Old Aug 17, 2004 | 08:43 PM
xzbit31's Avatar
xzbit31
Unhappy instrament cluster / ABS light sensor
First where is the sensor for the ABS located. (the light is on on my 4.2L F150)
Second is there a instament panel cluster out there for a 4.2L Manual Tran F150 with a Tach????
Old Aug 17, 2004 | 09:15 PM
StorminTexan's Avatar
StorminTexan
ABS Sensor is on the rear diff at the top next to the driveshaft.. Easier to reach it on the driver side..
As for Tachs..
I have a guy who sells them for 154.00 with the tach on it (From Automatics).. He has the hardware to set it up to automatically retrieve your key code on your key and store it.. ***NOTE: If you have a Ford with the big key it has a code that is kept in the instrument cluster inorder to start the truck. If you replace a cluster without having it set back to learn mode it wont let you start your vehicle..*** Also he can program your mileage.. I recommend 5000 miles ahead of your current mileage when you order so that you can install it right when you hit the correct mileage..
Here's his information
His name is Charlie, I cant post his email but if you send me an email I will write you back with his.. My email is in my profile..
Old Aug 18, 2004 | 09:55 AM
Habe's Avatar
Habe
StorminTexan
I can't e-mail yet as I do not have enough post's. Could you contact me? I would be interested in one of the clusters.
Old Aug 18, 2004 | 11:39 AM
StorminTexan
im on yahoo msg as
StorminTexan
email me at StorminTexan @ Yahoo . Com
take the spaces out
