Bronco II Ford Bronco II
Brake line question
Old Aug 17, 2004 | 08:11 PM
Mudder's Avatar
Mudder
Brake line question
I just bought a 4 inch lift for my 89 bronco II,i was all set to put it on then i saw something that didnt look right,will the brake lines need to be extended when i put my lift on? if so i gotta order bigger brake lines! please help! thanks in advance
Old Aug 17, 2004 | 09:14 PM
GrayRanger4x4's Avatar
GrayRanger4x4
You can get steel braded brakes lines the leight you need.Get the leight you need to mesure with the wheel at full drop.The lines run from stock hard line to the caliper where the stock rubber lines are.Hope this helps.
Old Aug 18, 2004 | 03:02 AM
Help I M Stuck's Avatar
Help I M Stuck
yep..you'll need brake line extensions..
www.4wheelparts.com sells them.
Old Aug 18, 2004 | 07:39 AM
Mudder's Avatar
Mudder
any idea how long ill need?
Old Aug 18, 2004 | 12:28 PM
GrayRanger4x4
NOPE! Like I said you need to mesure from the stock hard line to the caliper with the wheel at full drop.Jack it up under the frame till the wheel comes off the ground That will be full drop.
Old Aug 18, 2004 | 02:56 PM
Help I M Stuck
here is a link where you can order them..
http://rockymountainsusp.com/W_brakes_Fd.htm
