Axle code
Old Aug 17, 2004 | 12:44 PM
Wagster's Avatar
Wagster
Axle code
1989 F150. Tag on rear axle cover has some numbers. I think the H8 02 is the rear ratio code. Anyone know what gears I have?
Brian
Old Aug 17, 2004 | 05:04 PM
sandrat's Avatar
sandrat
According to a chart in the tech articles section of this site, it's a 3.08 ratio limited slip model.
Old Aug 17, 2004 | 05:49 PM
Wagster's Avatar
Wagster
Thank you. Thought maybe they were a little steeper considering I am pulling 2750 RPM at 60MPH (C6 3speed trans).
Old Aug 17, 2004 | 09:22 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Sounds like your tires are small diameter or your torque converter slips alot to be running that high of rpm at that low speed with those high gears.... I run about 3000 rpms @ 60mph with 4.56 gears and 33" tires with a C6 trans. Maybe a previous owner changed the gears in your truck, or maybe your speedo is off?
Old Aug 17, 2004 | 09:29 PM
Wagster's Avatar
Wagster
Trans is newly rebuilt by a reputable center, added a beast of a shift kit! Definitley NO slippage. Tires are 235/75/R15, which is stock. I know the speedo is dead on, I checked it with a buddy driving next to me. Gear change, doubt it, although I did think about that, I bought the truck from an old man, original owner, only 85k and it is an '89. I don't think he'd change ft/rr gears. I am averaging 12.5-13 MPG though in mixed driving which is OK with me for right now.
Thanks,
Brian
Old Aug 18, 2004 | 11:57 AM
IHUNT's Avatar
IHUNT
I got a 300 with a 4 speed od. my rear gear is a 3.55. I get 11-13 mpg. with 31"
2600 rpm at 70 miles per hour.
so your not to far from the same ratio.
Old Aug 18, 2004 | 12:29 PM
Wagster's Avatar
Wagster
I am thinking of going to 31" tires to help, although that will hurt the low end a bit. I need to replace the exhaust first.,
