injector failure
Old Aug 17, 2004 | 12:12 PM
fordman428's Avatar
fordman428
injector failure
whats the sign of injectors failing to work properly.
Old Aug 17, 2004 | 01:11 PM
hiondeisel's Avatar
hiondeisel
running rough would be the first thing to notice.... if running rough, there is a check to find the culprit injector... crack the injector lines one at a time listeneing for a change in the way it runs. re-tighten and continue to the next and so on.. running rougher when injector line is cracked means good injector...if no change in engine running that is the offending injector... it is a bit messy but worth the time...
Old Aug 17, 2004 | 09:33 PM
fnvford's Avatar
fnvford
hell, youll be able to feel them pumping, and he is correct cracking each one will show the culprit
Old Aug 18, 2004 | 11:21 AM
fordman428's Avatar
fordman428
could it possibly smoke black more if an injector is stuck or something.
