timing.
Old Aug 16, 2004 | 06:05 PM
psycocrazy's Avatar
psycocrazy
timing.
ok yall im needin to know how to set my timing. im gonna try to get a timing light this weekend so i can check it. but i need to know how to check it. thanx yall
Old Aug 16, 2004 | 07:39 PM
psycocrazy's Avatar
psycocrazy
on another note, the truck is surging thru all gears. i was told to check the timing, o2 sensor, the catalitic converter, and spark plugs. so yeah how do i change the o2 sensor?
thanx
Old Aug 16, 2004 | 08:44 PM
Ken00's Avatar
Ken00
You need to pull the spout connector, plug at the end of a wire near the distributor. Make sure the idle speed is correct, connect the pickup wire to #1, connect battery connections, mark the pointer with whiteout, make sure all is clear, start engine and test.
I would start by test fuel pressure and checking for codes, see the links in the tech info thread on these topics.
O2 is threaded into the down pipe on the passengers side, on top.
Old Aug 17, 2004 | 05:54 PM
psycocrazy's Avatar
psycocrazy
no codes and fuel pressure is ok. im gonna check the o2 sensor next.
