Overhead Console
Old Aug 16, 2004 | 10:43 AM
jonm61's Avatar
jonm61
Overhead Console
I'm looking for some ideas from anyone who has installed an overhead console in an X that didn't come with one.
I installed my console this weekend and everything is working great, with one exception. I hooked up the grey/black wire that connects to the speed sensor. I used a self tapping connector and attached the console wire to the grey/black wire coming out of the GEM, right behind the radio. The temperature reading is accurate, as long as I'm on the highway & moving at highway speed. If I'm driving in the city or get stuck in a slow down on the highway, the temperature goes up. The other day I passed a sign showing the temperature and the reading on my console was 8 degrees higher. By the time I got home, it showed 92 when it was only 78 outside.
Anyone have any ideas on how to troubleshoot this?
Thanks!
Old Aug 16, 2004 | 02:07 PM
Steina's Avatar
Steina
CO River Rat
Do you have the correct temp sensor probe?
Steve
Old Aug 16, 2004 | 02:11 PM
jonm61's Avatar
jonm61
I don't know, actually. The temp sensor probe & the overhead console came from different boneyards. How can I tell if they're a match?
Old Aug 16, 2004 | 02:34 PM
Steina's Avatar
Steina
CO River Rat
If they came from the same year/model then you're probably OK. If not - how chummy are you with your local Ford parts department? Give them the year/model the probe came from and see if the probe part # is the same as the year/model you pulled the console from.
Steve
Old Aug 16, 2004 | 05:31 PM
jonm61's Avatar
jonm61
Ok, thanks. I'll have to figure something out. I bought the console on Ebay but pulled the probe myself, and I don't know what year either truck was. I didn't realize there were different ones for different years.
Old Aug 16, 2004 | 06:01 PM
Steina's Avatar
Steina
CO River Rat
There may not be - just a guess. Maybe the probe is picking up condensor/radiator heat at low speeds; try putting a piece of insulation behind it.
Steve
Old Aug 16, 2004 | 08:26 PM
jclj2003's Avatar
jclj2003
or u could move it someware else
this is how i installed mine hope this helps
http://www.cardomain.com/member_page...=296394&page=3
Old Aug 16, 2004 | 09:38 PM
jonm61's Avatar
jonm61
Those are the instructions I followed as well. I'll try putting it somewhere else first....right now it's on the headlight side of the post next to the radiator. The one I pulled wasn't mounted, it was hanging loose, so I wasn't sure exactly where it was supposed to go....I just mounted it using a hole I found behind the grill, between the radiator & headlight.
jbwilli
Jun 3, 2023 10:38 PM
Brandiesel928
Feb 19, 2017 12:27 PM
WB4IUY
Aug 20, 2016 07:59 PM
fooey
23
Nov 21, 2005 11:02 AM
truckalpers
1997 - 2003 F150
Feb 3, 2005 01:14 PM
