Need Some Info
Old Aug 16, 2004 | 10:24 AM
cheechio's Avatar
cheechio
Need Some Info
I have a 95 extened cab someone gave me 35 x 12.50 tires for free but i need to lift up the front end at least 3 inches any suggestions?
Old Aug 16, 2004 | 02:20 PM
fordtradition's Avatar
fordtradition
if your truck is a 2wd I wouldn't bother with putting on 35's. would be worth it for a 4wd truck. basically then only way to get them to fit is a lift kit, or some major trimming of your fenders, tires will rubb in turns with just the fender trimming. the largest tires that will fit a 2wd is 31-10.50's. 4wd 33-12.50's. both with little or no rubbing. quite a job to try and fit 35's. 3 inch lift kit will do the trick though.
