spark plugs and compression
Old Aug 16, 2004 | 08:25 AM
76 F150 Ranger XLT's Avatar
76 F150 Ranger XLT
This is kinda goofy, but I remember reading somewhere (it may have been a Chevy buildup in a magazine; sorry) that if you remove the spark plug gasket (washer?), the plug takes up more space in the combustion chamber and increases compression. The article claimed it reduced the chamber volume by about 1 cc (seems high to me). Could you do this with an FE? What are the consequences? It seems like the spark plug gasket is there for a reason and you may actually lose compression if it leaks.
Old Aug 16, 2004 | 10:16 AM
Freightrain's Avatar
Freightrain
Sounds like a Chebby story......
.....and it picked up 20 hp......
The washer is the gasket/seal. I would see a bigger issue with keeping a seal then picking up ANY compression. We're talking less than a drop of water here...maybe. Not worth even measuring.
Maybe Warren Johnson did a test to see if it made a difference. I don't see any of us noticing a difference.
Old Aug 16, 2004 | 10:46 AM
BB's Avatar
BB
We don't run gaskets on the plugs for a FE. Instead the seat is tapered, much better heat transfer from the plug to head.
Old Aug 16, 2004 | 12:17 PM
76 F150 Ranger XLT
OK, that makes sense. Better heat transfer, cooler plug temperatures, less chance for preignition (or is it detonation? I always confuse the two).
BB,
Is there a trick to machining the taper or can any decent machinist figure it out? Is this sort of common knowledge among machinists?
Even if I never use them, I love learning all these little tricks that people use when building an engine. Thanks for the info.
Old Aug 16, 2004 | 12:28 PM
tastyklair's Avatar
tastyklair
Even though it is a minute amount of distance we are talking about, if the threaded area of the plug begins to stick into the chamber that is going to be a source for detonation to start. Thats why plugs are made in different "reaches". If you put the right heat range but wrong reach in a hole, that end of the plugs' threads are going to get glowing hot real quick. Stick with the gasket.
Old Aug 16, 2004 | 12:39 PM
BB's Avatar
BB
Originally Posted by 76 F150 Ranger XLT
BB,
I've never had to screw around with the seats in the heads. That's the way they come from the factory and never had a problem with them sealing.
When changing plugs, I like to wipe down the seat to make sure there's no crud. If your engine is pumping oil, you'd be surprised how much can get past the threads.
Old Aug 16, 2004 | 12:53 PM
76 F150 Ranger XLT
Huh. They are already tapered. I did not know that.
Old Aug 16, 2004 | 02:19 PM
Freightrain
Oops....well I guess I need to clarify........only EBOK heads need gaskets!! Doh!
Ya, factory heads don't have gaskets.
