Fuel gage not working-found the cause
The gage had stopped working on the front tank. I dropped the tank. Found out the float had a pin hole & a small crack about 1" apart. These were in the indention where the sending unit wire loop holds it.
I called Autozone and Advance. Seems you can't buy just the float. You have to buy the sending unit. It was a cool $95.00. WOW!
So, I thought I would try and fix it. I removed it from the wire loop, shook it till ALL the fuel was out, then wire brushed the two areas till they were clean. Then I brushed on some flux. The solder will not stick if this is not done.
I used a soldering iron and applied acid core solder. Then I let it cool, put it back in the wire loop. I oriented the float so the fixed areas would be up when in the tank.
Installed the tank back in the truck. I crossed my fingers and added fuel and the gage was working.
This may not be the cause of yours. But it could be. Hope this helps someone.
Clava
1995 F-150 4x4 5.8 E4OD ext cab 188,000 miles
Clava
Hey, awesome fix, Clava. My uncle's gauge on his Saturn daily driver is a bit whacko. When he fills it up it'll read wherever it was when he went to fill up, and won't read the actual level until it drops to about 3/4 of a tank or so... weird, huh? Anyway, I might suggest this fix to him, if he's interested. Thanks for the tip.
