porting is it worth it
Old Aug 15, 2004 | 08:44 PM
78_ford_F150's Avatar
78_ford_F150
im geting a set of 400 heads rebuilt is it worth the money to get them ported a bit or not and if so what would it cost. thanx justin
Old Aug 15, 2004 | 08:52 PM
monsterbaby's Avatar
monsterbaby
for a stock rebuild or a mild street build I would have to say no it's not worth paying someone to port your heads, if you have a die grinder, and want to clean them up a little fine but not paying someone to do it, the amount of hp increase just is too high better spend the same money on good parts, and make it dependable, or maybe having it balanced that would probably be cheaper than a port job, and do more good both for performance and longevity of the engine
Old Aug 15, 2004 | 09:07 PM
Torque1st's Avatar
Torque1st
Posting Legend
If you don't know what you are doing you can mess up a valve job or your heads pretty quick. Monster is right, use the money to balance the engine. Use the time to clean up and doublecheck the assy.
Old Aug 15, 2004 | 09:31 PM
battered_bronco's Avatar
battered_bronco
just hit the raw cating anyway 80/120+ grit not sure if or how much it helps but as long as you arenot trying to change much just clean it up abit
Old Aug 18, 2004 | 05:35 PM
RockyMtnF250's Avatar
RockyMtnF250
I spent $225 to have my heads ported by someone that knew what they were doing, I think it was worth every penny. Yes I had the engine balanced also, it's a good idea if you want it to last.
