Mudmotors
Old Aug 15, 2004 | 07:01 PM
bigreave's Avatar
bigreave
Mudmotors
i was one of my duckhunting boards and i ran acroos a idea to make your own mudmotor . Has anyone done this or knows how?
Old Aug 15, 2004 | 11:58 PM
ShawnZ's Avatar
ShawnZ
duckhunting boards??? LINKY?
Old Aug 16, 2004 | 11:50 AM
bigreave's Avatar
bigreave
http://www.duckhuntingchat.com/
http://www.refugeforums.com/refuge/f...p?s=&forumid=4
here are the two i visit the most
James's f_1_fiddy01's Avatar
James's f_1_fiddy01
call me stupid but whats a "mudmotor"?
Old Aug 16, 2004 | 11:59 AM
bigreave's Avatar
bigreave
it's an outboard that can run in 6 inches of water that has an extended real long prop that is primarilary used in marshes and shallow water
Old Aug 16, 2004 | 12:10 PM
James's f_1_fiddy01
ooh ok i seen those before, sometimes they have a long driveshaft hooked up to a 12hp briggs&stratton engine or something equivelant right? in Fl they call em Swamp Trollers
Old Aug 16, 2004 | 12:16 PM
bigreave's Avatar
bigreave
yep thats what they are
Old Aug 16, 2004 | 12:27 PM
James's f_1_fiddy01
well Reave i got a buddy who made 2 for his dad and grampa's boat....he said he used 20hp kohler engines with a belt driven shaft he said belt driven was in case it hit a root or tangled in weeds it wouldnt rip the engine off its stand it would slip the belts...and you could just dis engage the belt drive and paddle away from the obstacle....he said to be sure to mount it on a THICK peice of wood like 1-1/2" plywood and secure that to the boat ....then run your shaft at a precise angle and the shaft is best to be balanced and have carrier bearings along the way down so it dont warp and shake the boat to death...he said to use a removable pulley on the engine so you can adjust the prop speed / RPM ratio accordingly...if you need more help ill ask him to sign in here to help ya
carid
Vendor Specials, Discounts, Product Announcements & Group Buys
Jul 17, 2018 06:41 AM
weadjust
13
May 10, 2006 10:04 AM
Aftrmidnite
Mar 14, 2004 02:54 PM
