Grille Installation
Old Aug 15, 2004 | 02:33 PM
Deacon Stanley's Avatar
Deacon Stanley
Grille Installation
Does anyone here have any experience installing the DJ Motorsports EX2 grill? I have a 1998 Expedition, and I want this grill. I have only modest mechanical skills and was wondering how easy it was to do. I was reading where some cutting was involved in this. If it is not that easy to install, I will just take it and have it done. Any help on this would be appreciated.
Old Aug 15, 2004 | 09:00 PM
tyger25's Avatar
tyger25
Pretty easy to do. Honeycomb grille came off with a little force, and you will need a dremel to smooth out the tabs. Here is my DJ Grille.
Old Aug 15, 2004 | 09:04 PM
Deacon Stanley
Would I be asking too much for detailed instructions on how to remove the old grill and install the new one. I'm very new to modding my own truck and am a little nervous and want to make sure that I don't mess something up.
Old Aug 15, 2004 | 09:23 PM
tyger25's Avatar
tyger25
Sure thing.
1.) Open hood and remove plastic trim panel covering the top of the grille assembly.
2.) Remove headlights by pushing headlight retaining clips rearward then pull upwards on the clips to release headlight housing. Pull headlight housing away from vehicle to remove bulb retaining ring. Remove headlight housing assembly from vehicle.
3.) Remove grille retaining screws located behind headlight openings. (2 on each side).
4.) Remove clips securing lower half of grille.
5.) Detatch screws securing upper half of grille, (6 on top), then remove grille.
(There are pictures to the above procedures in the Haynes Repair Manual)
Now you have to remove the honeycomb grille. Just push and pull to break it apart. Once this is out, you will have to dremel the tabs down. Then just fit your grille in place, drill the new holes for the rivets, then rivet the new grille in place! Now just reassemble.
Old Sep 18, 2004 | 03:24 PM
78Explorer's Avatar
78Explorer
Thumbs up
tyger,
NICE Expy! Just like mine (except mine's stock at this point). Where'd you get the flame guages? How long have you owned yours? How many miles are on it? What problems have you encountered?
Just bought mine last Monday with 101,400 miles on it and don't know any of the service/maintenance history. Do ya think Ford dealership would mind running the vin through their system and printing me what's been repaired/replaced by Ford?
Thanks,
Scott
