Torque converter clutch shudder or vibration...
Old 08-15-2004, 07:55 AM
mikefox670's Avatar
mikefox670
mikefox670 is offline
I have a torque converter clutch shudder or vibration which occurs under light to moderate acceleration above (35 mph) while in 3rd or 4th gear or on 3-4/4-3 shifts. This issue occurs about every fifty miles. I’m told this condition may be more noticeable on higher mileage vehicles when the torque converter clutch engages or disengages on light to moderate acceleration (mine has 110,000).
I have changed the transmission fluid & filter. This is the first time the transmission has been serviced for I found the factory dip stick plug in the pan. Ford says changing the transmission fluid should reduce the the possibility of shudder/vibration but too no avail.
Also found a sticker on transmission pan that read:
“1998 4R70W EARLY CONCERN DEFIINTION
PRIRO TO REPAIR, See, TSB 97-17”.
1998 Ford F150
4.6L 110,000 miles
4R70W
Old 08-15-2004, 10:32 AM
bosshoss's Avatar
bosshoss
bosshoss is offline
What type of transmission fluid did you put back in? Did you also change the converter fluid?
Old 08-15-2004, 12:14 PM
mikefox670's Avatar
mikefox670
I put five quarts of Mercon V and did not change the converter fluid.
Old 08-15-2004, 04:44 PM
gfreek's Avatar
gfreek
gfreek is offline
There is a product that comes in a tube or container just for your shudder problem. Don't remember the name though. I used it in my Caravan when I had a shudder problem and it took care of it.
Old 08-15-2004, 05:41 PM
superrangerman2002's Avatar
superrangerman2002
superrangerman2002 is offline
I would bet that the fluid in the torque converter is of the non-Merc V nature, and is your problem.
The whole tranny holds ~14qts, and just the pan is ~5 qts.
It may have been the first time the pan was dropped, but doesn't mean that the tranny wasnt flushed at some quicke lube place that put in plain jane atf.
I would try do a full tranny flush with a Mercon V rated fluid and see if that corrects the problem.
There is a nice write up in the Tech Article section for the Diy'er.
Old 08-15-2004, 06:53 PM
Mojave2k's Avatar
Mojave2k
Mojave2k is offline
I agree with superrangerman2002.. First check the specks and see which fluid is correct for 1998, then have the whole trannie flushed, 13-14 qts. Unfortunately if the trans. was not serviced every 50k or so.. or the previous owner towed the Titanic without servicing the trannie it could be too late for the converter.. Lets hope for the best.. Also you can save a lot of converter heat and wear by leaving the truck out of overdrive driving in town at 45 mph or less.. This will keep the converter locked in 3rd, and without constantly slipping as it does in 4th at town speeds it can last the life of the truck... My buddys 1991 Town car was just sold with 240K on the original engine and trannie, never had the heads off..still running fine though it was using about a quart of 10/30 every 1000 miles.. good old 4.6 valve seals...
Old 08-15-2004, 08:07 PM
mikefox670's Avatar
mikefox670
I did a complete thirteen quart flush with Mercon V and it solved the problem.
Thanks to all that replied.
Old 08-15-2004, 10:15 PM
Mojave2k's Avatar
Mojave2k
Mojave2k is offline
Glad to hear it .. Don't forget to stay out of overdrive in town and save that Converter..
Old 08-16-2004, 05:27 PM
superrangerman2002
Glad to hear that it was a simple and cheap fix!
Jmanb13
03-10-2020 09:12 PM
Buck268
2009 - 2014 F150
07-17-2013 11:27 AM
KNE350
04-18-2013 06:42 AM
PW01
01-04-2009 07:54 PM
bassettg
12-08-2004 09:56 AM
Quick Reply: Torque converter clutch shudder or vibration...
