Highboy Steering Conversion Question?? Once Again
Old Aug 18, 2004 | 07:35 AM
rodbender's Avatar
rodbender
Originally Posted by krewat
Did you notch the cross-member? Just curious - that's the same thing I used... except the drag-link (mostly because I couldn't find a good one in the junkyard, so I'm not entirely sure I needed a longer one or not).
No I didn't the one thing I did have to modify was the inner fenderwell and length of the steering shaft to the box. The clearance from the pitman arm and frame is pretty tight but it's been working for about ten years now.
Old Aug 18, 2004 | 04:06 PM
haten'chevs's Avatar
haten'chevs
Everything I keep reading on this topic everyone is using the 78-79 steering box. I have all the parts out of a 84' 250 diesel. Can I use these parts or wont they work?
Old Aug 18, 2004 | 04:20 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yeah, fenderwell for me too, and length of steering shaft. No interference... I believe it was a '79 F250 box, it sure turns my 33" tires with one finger...
haten'chevs, you have to determine that for yourself probably. The '79 box is a known thing to do, way back from the 80's when I heard about it. But I still measured everything out, took out the old parts, lined up the new, measured, measured and re-measured... then fab the "box out" of the inner frame where the box goes. Even though it's a "known" thing to do, there's still an "art" to it...
Anyone else out there use '80's boxes?
art k.
Old Aug 19, 2004 | 07:13 AM
rodbender's Avatar
rodbender
That's nice to know it'll turn the big tires as I'm finally going to put some on my truck this fall.
Highboy74
Dec 10, 2016 05:54 PM
JeffStrachan
Sep 5, 2016 12:06 AM
idahoborn11
Oct 19, 2015 09:28 AM
supercabfreak
42
Oct 31, 2013 05:33 PM
highboy1975
Offroad & 4x4
Jan 8, 2009 12:41 AM
