Pcv?
Old Aug 15, 2004 | 04:43 PM
fordloverf2501970's Avatar
fordloverf2501970
just a oil cap on drivers side - pcv on the passenger side
Old Aug 16, 2004 | 01:26 AM
scroob's Avatar
scroob
"The gunk could be from not changing oil regularly! Ford engines ran for years w/o PCV!"
And if you ever tore apart an engine that had only a road draft tube, you'd see why the switch was made. It was not uncommon to have so much sludge in the valve covers that the rocker arms left prints in it. This was the main reason that engines of those days were considered champs if they made it to 100,000 miles.
Old Aug 16, 2004 | 01:29 AM
scroob's Avatar
scroob
"just a oil cap on drivers side - pcv on the passenger side"
The factory setup was an oil cap with a hose that went to the breather. Someone has changed yours out.
The PCV system cannot work properly unless there is a filtered air intake on the other valve cover.
greagin
Escape & Escape Hybrid
Dec 27, 2014 05:00 PM
Mr Hanky
Modular V10 (6.8l)
Nov 7, 2010 01:35 AM
Easy150
1997 - 2003 F150
Oct 2, 2007 12:00 PM
LARIAT 85
Sep 28, 2007 05:34 PM
bareaneye
13
Jul 24, 2007 06:10 PM
