Aerostar Ford Aerostar
Transmission
Old Aug 13, 2004 | 03:36 PM
LBMNTN's Avatar
LBMNTN
Transmission
Have a 93 3.0 with 188,000 miles. Still runs fine, but transmission will not upshift from 2 to 3.
New Vacuum modulator installed and fluid changed.
Also has the lag when going into reverse.
Any suggestions to get 3rd gear back?
Old Aug 15, 2004 | 07:32 AM
mojo hobo's Avatar
mojo hobo
Thumbs up Just A Suggestion
I'm not sure but with the mileage you have maybe it could be time to adjust the bands.It should be found on the driver's side of the tranny,check for specs on this forum or get the specs.from a manuel or tranny shop.I know I have to check mine before I leave on a east to westcoast trip which I hope my tranny can make it.I will keep you posted before I leave,just a couple of weeks left.
Mojo Hobo
Old Aug 15, 2004 | 12:07 PM
joe2's Avatar
joe2
Band specs for a A4LD is 10ftlb. Loosen the lock nut, tighten the band adjusting screw to 10ftlbs or 120 inch pounds depending on what type torque wrench you are using. Once that is done back the adjusting screw out 2 turns. Hold the adjusting screw in place and tighten the lock nut back down. Both Adjusting screws are withen 6 inches of each other so if you find one the other is close by.
MojoHobo-I just took my 89 shorty 3.0L from seattle to San Diego and back- Only have 70K on the car and still managed to loose reverse in Oregon on the trip back (good old A4LD strikes again), lots of Mountains here and had the vehicle loaded pretty good, I think I should have used D instead of the OD option due to the weight. Lots of posts in this forum about that issue, most people have luck using D vice OD on long trips with weight. I would highly reccomend fluid and filter change before and after the trip. Good luck and have fun
Joe
Old Aug 15, 2004 | 07:44 PM
mojo hobo's Avatar
mojo hobo
Question Scary
Joe
Hi Joe 2
Thanks alot for the info.just a little scary I have 130000 kms. and I'll be travelling from the GREAT WHITE NORTH Canada side.I'll be pretty loaded with belongings and I did change fluid and filter,don't know if you read it about my mystery filter,own a 94 but the tranny was rebuilt with a 93 tranny or components?Well I'll keep you guys posted.
Mojo Hobo
Old Aug 15, 2004 | 09:32 PM
joe2's Avatar
joe2
Have no fear, as long as it keeps going forward all is well. No reverse is a pain, however, its just a matter of finding the right parking spot or bringing my two teenage boys with me. Either way works fine. I did see the post as to the tranny filter, as a matter of fact when I did mine I was thinking about that exact post. Lucky for me the filter was only 1 bolt and the new one matched perfectly. Enjoy
Joe
PS- might think about bringing some extra tranny fluid and maybe a bottle of tranny stop leak for emergency purposes only. I brought everything I thought I would need if some thing went wrong, and there I was Half way up a verry step graded mountain on Hiway 5 in the HOOOOOT california waste land with some pretty cranky family members and a tranny that was puking fluid from the seal all over the exhaust pipe, made soo much smoke I thought I blew the engine, needless to say I will never forget that stuff ever again.
Old Aug 16, 2004 | 09:17 PM
mojo hobo's Avatar
mojo hobo
thanks for the info. know how you feel.
Joe
Thanks again for the info.But boy do I know what you mean about the smoke show.Cars all aruond me steered away,must of thought this van is a goner,so did I at first.Now I even carry a Diaper for the next episode,an oil pan to put under so not to make a mess or leave an A4LD trade mark around.Will keep you guys posted.
Mojo Hobo
motard
Mar 20, 2017 08:50 AM
66 sandrail
Jan 3, 2017 05:31 PM
rustyranger92
1983 - 2012 Ranger & B-Series
Oct 12, 2016 08:36 AM
dspeer75
Feb 28, 2009 08:41 PM
