Stuck Spark Plug
Old Aug 13, 2004 | 03:14 PM
AbramsM1's Avatar
AbramsM1
Stuck Spark Plug
1973 F250. The second spark plug from the front on the passenger side will not come out with a 1/2" drive socket and wrench. Whats the deal with that? I am afraid of stripping out the threads on the head. That seems like it would really suck. Should I just apply some massive torque and see what happens or what?
Thanks in advance,
Abrams
Old Aug 13, 2004 | 03:20 PM
michaelbrainardatwor's Avatar
apply some CRC Power Lube ( or at least wd40 ) let it set over night and soak in good...then try. CRC is great stuff.
Question to the rest of you...would it help if the heads were hot?
Old Aug 13, 2004 | 03:23 PM
AbramsM1's Avatar
AbramsM1
I'll try soaking it overnight. By the way, It is a 360.
Thanks,
Abrams
Old Aug 14, 2004 | 01:00 AM
rebocardo's Avatar
rebocardo
Try taking it out when the engine is hot!
Before applying massive amounts of torque I would use a rocking motion with an impact wrench on the lightest setting and maybe turn down the psi at the compressor.
Old Aug 14, 2004 | 06:27 AM
banjopicker66's Avatar
banjopicker66
Try tightening it to break it loose.
Be sure to use heat and solvent first, though!
Old Aug 14, 2004 | 07:53 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Just my 2 cents, Like said above, try using some Liquid Wrench, Put on a heavy coat on it..and let it set.. Your not going to hurt the theads in the head, because the plug is softer metal than the head is.... Good luck!!
Russ
Old Aug 14, 2004 | 09:48 AM
AbramsM1's Avatar
AbramsM1
Is the plug really a softer metal than the heads? I just remember somebody having a spark plug strip out a head one time... maybe it was aluminum.
Thanks for all the help. Wish me luck.
-Abrams
Old Aug 14, 2004 | 09:54 AM
390fe's Avatar
390fe
When I bought my '70, I had to use an impact gun to get those plugs out. I didn't use and solvent, and the engine was hot. No damage done, for what it's worth.
Old Aug 14, 2004 | 01:50 PM
CrazyAirman's Avatar
CrazyAirman
-Abrams
Yup, the plugs are softer. I have noticed that the majority of FE's I have worked on over the years have a plug or two that will be stubborn. The correct way is penatrating oil ( brand not important) overnight, then hit em with an impact. Or, just hit them with an impact right now, and they will come out, without damage to the head, but thats if you are impatient like me
Old Aug 14, 2004 | 01:59 PM
rusty70f100's Avatar
rusty70f100
Just a tip, when you finally do get 'em out, put some anti-sieze on the threads. Prevents this kind of thing in the future.
Old Aug 14, 2004 | 02:13 PM
CrazyAirman
Yeah forgot that... thats probably the BEST advice yet
Old Aug 14, 2004 | 04:05 PM
rebocardo's Avatar
rebocardo
The most important thing is to do it with the engine hot. The block will be at the max. expansion and the plugs will end up being cooler then the block after it sits for a few minutes because the block will retain its heat. The thread on a spark plug is designed to compress so it seals the combustion chamber. As such, using WD40 etc etc does very little to free a frozen plug. I would vacuum the hole afterwards to get any slivers of metal from the thread out of the engine.
ymirr
Apr 6, 2017 07:42 PM
doughogan
2009 - 2014 F150
Oct 11, 2016 02:29 PM
HelenB
May 17, 2016 04:38 PM
zech
1983 - 2012 Ranger & B-Series
Sep 18, 2015 09:25 AM
getsch58
Jun 22, 2006 09:00 AM
