Stuck piston ring
Old Aug 13, 2004 | 02:51 PM
Trigger_17's Avatar
Trigger_17
Stuck piston ring
the rings in one of the cylinders is frozen causing the motor to burn oil. how hard a job is this to replace? somebody told me i think i need to take the whole piston out. should i replace the others while im at it?
Old Aug 13, 2004 | 03:56 PM
andym's Avatar
andym
Are you sure it's rings? It could be valve stem seals leaking oil into the combustion chamber, too.
Old Aug 13, 2004 | 04:31 PM
fordflaresides's Avatar
fordflaresides
Piston rings wear out for a reason, replacing them is only a temporary solution, you'll need too have the cylinders bored and honed too.
