1998 Explorer Alarm problem
Old Feb 25, 2001 | 07:05 PM
mlr51's Avatar
mlr51
Several times now the lights have started flashing and the horn has started blowing at random like someone had pushed the panic button on the remote and I know that it wasnt pushed, Does anyone know what I can do to stop this or how to turn the alarm off? Thank you, Mike.
Old Mar 14, 2001 | 04:22 AM
htram's Avatar
htram
Hi,
When does your alarm go off? When there's wind or car driving by? A few months ago I started to have this problem. The problem was traced to the switch/alarm sensor under the hood. It somehow got shifted so that it barely makes contact with the hood. When wind blows or car drive by and rattles the hood, my alarm would go off. I repositioned the switch to make better contact with the hood and the problem went away.
Hope that helps.
Old Apr 13, 2001 | 08:55 AM
brakk's Avatar
brakk
I have had the same problem with my 97 explorer. I thought it was the back door sensor since it seams to happen more often when something slides back against the door, but, I rember seeing the hood sensor being bent a while back and straightening it back. Is there a way to tell which sensor is setting it off, and if it is the back door, where is the sensor located, I looked for it, but can't seem to find it. (i was just going to disable it if I had to).
I've noticed it happens more often in the evenings and the mornings (ie: tempreture changing). but it goes off other times randomly also. I've had to start locking the doors manually so it won't arm the alarm since i don't want to upset my neighbors.
Old Apr 24, 2001 | 12:24 AM
htram's Avatar
htram
Hi,
You can do a simple check to see if any door is open by pressing the lock button twice. If you hear two honks then it means one of the door is open. I don't think the hood is affected by this test though so if you get only one honk then all your doors are secure.
The hood switch, which is located on the right side of the engine compartment, barely made contact when the hood is closed. When there was high wind or one of those guys who wants to share music with the world drives by, the alarm goes off.
Actually, if the alarm is sensitive, you can try one of these. With the doors and hood closed, try tugging (or pushing from the inside) on the doors/hood and see if the alarms goes off. I remember after tracing the problem to the hood, I tried to lift it, even in its closed and latched position, and the alarm would go off.
I'm sorry I don't know where the sensor is for the rear door though but I will post the location if I find out.
Old Apr 24, 2001 | 12:53 AM
htram's Avatar
htram
Old Mar 5, 2006 | 09:18 PM
cnajp's Avatar
cnajp
Can a person remove the security system hood pin?
Hello,
Can a person remove the security system switch pin under the hood and reset the security system and the system work correctly? I like being able to use the keyless entry fob for my car, but when I press the lock button on the fob, the alarm goes off after 30 seconds. I found out that this occurs because of the hood pin being bent. I have readjusted it SEVERAL times, and if possible, I would like to just rid of the pin all together.
1994 Ford Explorer Eddie Bauer
cardboard
2009 - 2014 F150
Mar 13, 2015 12:26 PM
randymacbc
Mar 21, 2012 01:23 PM
915855
Jun 14, 2010 04:13 PM
jmusenkh
1997 - 2003 F150
Sep 21, 2006 01:47 PM
Merculous
1997 - 2003 F150
May 11, 2006 07:11 PM
