got a predator, now what?
Only running the 65hp mode.
question is should i redo the exhaust system with a different one?
If so which one?
what about gauges?
any information would be helpful
If so which one?
what about gauges?
an EGT and a 3.5 in down pipe with the muffler hacked off is sufficient if u dont beat on ur truck.
check out the methanol/water thread. then u wont need to worry bout EGT
If so which one?
what about gauges?
The 'add ons' probably depend on how you plan on driving or towing, and how the truck with the new found power will be used.. OR, if you just want even more power for your buck.. A EGT gauge is a good idea 'just' to keep an eye on the exhaust temps, and to protect the mill, as well as the warranty.. Cheap insurance.. With the truck in stock configuration (no mods) you shouldn't see any damaging temps if your not hammering the throttle for long periods of time on steep grades ect., or up in the altitudes/heat pulling a load.. Mine is in stock profile and the temps are 'well within' the safe range even on a hard carpet pressing, in the 65HP tune.. An intake and exhaust isn't a must, but would help to lower egt, and add to the fun!!!
......................HP.......................... ....
isn't there always a but...
My funds are minimal while building this house...
so I had to decide ...
if I got gauges and found that I HAD a temp problem I would have to get exhaust and/or intake anyway...
SO I chose to attack the CURE first rather than to measure it first...
put an aluminized turbo back exhaust system with 3.5" dp that opens up to 4" all the way back with a flow thru muffler... have had the predator on since 1-15-04 in DALLAS heat and with my fast driving and not had any problems...
If so which one?
what about gauges?
Enjoy FTE
If so which one?
what about gauges?
I am running the Predator in 100HP mode, stock exhaust, no gauges. Now, for the kind of driving I do 99% of the time, I don't feel that it is an issue. When I tow really heavy things, I put in the tow-safe program. Otherwise, it's 100HP mode and Git-Er-Done
. Based on my research, I don't have any negative feelings about it.I would put in an EGT gauge and see how your temps are. It's cheap insurance and my guess is that you will not feel the need to tinker with the exhaust, at least for the purpose of lowering EGT's.
I plan to add exhaust and Methanol/water injection some time soon.
I haven't noticed excessive EGTs but I never tow anything.
Mike
What you do NOW is go out and embarress a couple of Duramesses and Dodge crummings...
...Then go do the stuff everyone else said.
"DiabloSport strongly recommends the use of larger diameter performance exhaust components and exhaust temperature gauges with the use of any performance diesel tuning."
anyways, what guages and exhausts are you peeps using? any warrenty problems with these mods?
I have a aluminized turbo back - 3.5" downpipe to 4" from downpipe back...
Neither of us have had a problem since we've been running the predator (got them in Jan timeframe...)
Is this a problem?
Did notice that my Mileage did go up, but about 1.5. but this happen more as I drove faster. From 60 to 70 over head mpg showed 16.2, but when i opened her up to 75 to 85+, the mpg increased 17.2.
the shifting was hard at first, but seems to have mellowed out.
I am planning to install a EGT gauge as soon as i can find one I like, And then I need a good mounting spot, I did see a fellow member that made a nice looking cupholder style on the cluster panel, Looked good, but wonder if you can do it alittle different.
Also, I will be changing the Exhaust sytem.
Which is good, Have Looked the MBR, What do you Guys think?
Thanks for all the good imput, It been Wonderful so Far
