I noted of late that with the A/C on - the V10 seems to be less responsive -- I would not think the A/C would reduce engine response to such a noteable degree - has any one else noticed this..
2004 F250 V10 Off Road 4x4 Flowmaster 70 K&N Air Filter
It shouldnt on wide open throttle as the compressor cuts off on hard accelleration. The loads under normal driving should be minimal unless there is a compressor dragging from near catastrophic failure. The added loads are both mechanical and electrical. I would think the most noticable drop would be from a heavily loaded vehicle while cruising. In all things which produce power, you cant get something for nothing. You must sacrifice some power to carry a load.
Well Boxcar 1974, I like the Flowmaster 70 - there is no noise in the cab and it seemed to improved my pulling power on mountain roads - not as loud as I thought it would be..had a 40 series on my old GMC pickup..Figure it will get a little louder after it has more wear and tear on it..
Just installed a K&N air filter - was running with A/C off and noticed the truck was shifting quicker and RPM readings had changed and to myself WOW what an improvement....howver, shortly afterwards I turned the A/C on...hahahaha- running with A/C most of time here in summer months- which prompted my question - I was surpised that it seem to pull the engine down so much - as you said, all of my vehicles show some degrade in get-up-and-go with A/C on - I really thought with the V10 engine it would be hardly noticeable..
For HomerWinzlow - truck only has 5th wheel hitch in bed....and everything considered - in O/D the trunk runs the same RPM's with a 5000 pound load as it does with only the hitch...my V10 engine really talks to me when I get on it - I love the truck. cheers
This is how I often describe gas chips and tuners to customers. I tell them to imagine turning off the air conditioner on a compact car going up a hill.
