Sponsored by: Real Truck
Turn Signal
Old Aug 12, 2004 | 05:21 PM
Black88GT's Avatar
Black88GT
Turn Signal
The little arm I use to turn signals on broke. Right works no problem, but I have to wiggle left to get it to go. Has this happened to anyone else? How much is the switch? How hard is the swap? Thanks
Old Aug 12, 2004 | 05:40 PM
fn250's Avatar
fn250
Unfortunately, the switch is an integrated Multi-function switch. The emergency lights, turn signals, and some other functions all tie together in the switch. Mine went out @ 20K miles so it was still covered by waranty.
Old Aug 12, 2004 | 05:43 PM
RedTaurus94's Avatar
RedTaurus94
I saw one once on ebay. Seems like it went for around $20 or $25, but I have slept several times since then. You might try doing a search there to see if you can find one.........
Old Aug 12, 2004 | 07:13 PM
HomerWinzlow's Avatar
HomerWinzlow
Just make sure you get the correct muliti function switch. They made at least one major change since 99 and the later model will not in any way work with the earlier truck.
Old Aug 15, 2004 | 12:29 PM
Black88GT's Avatar
Black88GT
Great to know. Ill probably just go to the dealer then.
Larry Grimes
Nov 24, 2014 04:39 PM
ktheavner
6.4L Power Stroke Diesel
Oct 2, 2014 07:02 PM
NickOlsen53
Apr 3, 2014 05:50 PM
mdjwahl
1997 - 2003 F150
Jul 18, 2007 09:50 AM
cliebold
Jul 24, 2002 04:25 PM
