Florida Chapter Join Chapter, Leader: Ronnie Shierling
dumb question
Old Aug 12, 2004 | 08:55 AM
tampabandit's Avatar
tampabandit
dumb question
Ok people...I finally found the transmission i have been looking for since march...but now im unsure if i have forgot how to re-install it...do i need to or should i do anything to it before i install back in..it is that same type of tranny the mazda 5 speed...and any idea on how to bleed the hydraulic clutch? thanx for any help...tim
Old Aug 14, 2004 | 08:12 PM
James's f_1_fiddy01's Avatar
James's f_1_fiddy01
no such thing as a stupid question bandit....allways glad to help out a fellow Ford owner you should be sure you use new parts like clutch plates etc....also throw out bearings use new....even if the tranny looks good change em its cheaper now than later.....now the bleeding is JUST like the brakes on your truck...pump pump pump pump ...hold...........loosten bleeder screw, let out pressure....still holding pedal....tighten bleeder screw....pump pump pump pump.....hold....and so on till you get a firm clutch.....be sure to regularly check the levels on the fluid to be sure you dont run her dry....if you need anything else shout.
