Sponsored by: Real Truck
Xm satellite antenna
Old Aug 12, 2004 | 08:05 AM
rmilchman's Avatar
rmilchman
I’m buying an xm radio and am trying to decide where to mount the antenna. I was considering the possibility of a magnetic mount and bringing the wire out through the break / bed lights. The only other choice I could think of is to drill and permanently mount. In my opinion both options have issues. With the magnetic mount I’m afraid of a possible water leak where the wire comes out of the light and also that the cable would have to ride a couple of inches against the paint possibly rubbing the paint off causing other problems. With drilling, well never liked drilling….
Old Aug 12, 2004 | 09:42 AM
cpufed's Avatar
cpufed
I have a small magnetic antenna for my XM that I just ran out the drivers side and then along the windshield weatherstrip. You can see the wire which is really no big deal. My truck is dark green so it doesn't stand out. I thought about drilling too, but decided against it.
Old Aug 12, 2004 | 09:43 AM
DougD's Avatar
DougD
I did the magnetic mount and it sits on my roof at the top corner of the drivers side post by the windshield rubber. It is almost invisible. People don't see it there unless I point it out.
Love my XM
Old Aug 12, 2004 | 09:48 AM
cpufed's Avatar
cpufed
Mine is more in the middle of the roof and like you said nobody really notices it.
Old Aug 12, 2004 | 09:59 AM
rmilchman's Avatar
rmilchman
Thanks for all the replies. Anyone have a problem with the wire rubbing off any paint?
Old Aug 12, 2004 | 10:00 AM
cpufed's Avatar
cpufed
Just keep the antenna in one place and if you have to move it make sure you lift it up first.
Old Aug 12, 2004 | 10:07 AM
rmilchman's Avatar
rmilchman
Great, just ordered a roady 2 and should have it this weekend. Bought it mostly to connect to home stereo but will also use it in the truck. It comes with both a cassette hook up and FM modulator. I'm hoping the modulator will work well in the truck. At home it will be hard wired into the stereo.
Old Aug 12, 2004 | 10:16 AM
DougD's Avatar
DougD
Depending on the stereo you have - I did a direct connect to the two audio inputs on the rear of my stereo. Ran the power from the cigarette plug rear. That will give you CD quality sound. Using the FM modulator/converter just gives you sound quailty to a good FM station.
The same direct connection can be used in your home stereo. Just remember to adjust you line output volume in your XM unit.
Old Aug 12, 2004 | 10:27 AM
matt1751's Avatar
matt1751
I have a Sirius tuner and ran my magnetic antenna through the 3rd brake light on my 04 CC, I put a little bit of clear silicone around the light and wire and have had no leaks,, I put the antenna about 6 inches from the light and works fine,,
Old Aug 12, 2004 | 12:13 PM
fireman28's Avatar
fireman28
I did like matt and ran mine out the brake light, but I didn't put any silicone on it. We had over 18 inches of rain in June and no leaks. just my .02
Old Aug 12, 2004 | 12:38 PM
rmilchman's Avatar
rmilchman
OK, guess I'm going to thru the brake light. Guess since no one has mentioned paint getting damaged I won't worry about that. I have the stock radio so I guess my last decission to make is throught the tape or FM.
Old Aug 12, 2004 | 02:19 PM
Oldchap's Avatar
Oldchap
If you have a supercab, pop out the back of the back seat. (Pull it up, then out) Behind it, there's vent holes to the outside, which wires can be fed thru, to a mag mount on the roof. Only downside is the exposed wire running up the back of the cab.
Old Aug 12, 2004 | 05:55 PM
mrc59's Avatar
mrc59
Mine's out the brakelight too. No issues. Truck is black, so nothing much shows. Plus, I have a shell, so no one can even see the tiny antenna unless they are 8' tall!
Old Aug 12, 2004 | 08:38 PM
DougD's Avatar
DougD
Out the front and under the window rubber is the best...
Old Aug 12, 2004 | 09:53 PM
Kable Guy's Avatar
Kable Guy
Terk makes an on glass antenna XM-11. Retails about $20.00. Works like the old on glass cell phone antennas. Also you don't have to worry about your paint or where to run the wire outside. only a 6" mast!
