avs carter help/info needed
Old Aug 12, 2004 | 05:46 AM
battered_bronco's Avatar
battered_bronco
ok these thing are the "same" as edels thunder kinda sorta
which brings the questions
what from edel can i use
can i use all thunder stuff on a old carter avs?
what off a AFB can i use?
ok the numbers i have recieved are K6 46398A thinking its K6 4639 8A as 4639 shows up as a p/n but no info) saw a reference to it being a 625 but also read that carter didn't publish CFM ratings
thanks i wish to get the old ready
ps also what can i coat(elctro-coat) parts with that is impervious to gas and fuel additive nickel ? i want a perma shiny surface
Old Aug 14, 2004 | 10:57 AM
battered_bronco
anybody know where i can find such info ?
please..purity please
Old Aug 14, 2004 | 02:45 PM
LxMan1's Avatar
LxMan1
Most of the Edelbrock AVS parts should interchange with your AVS.
Old Aug 19, 2004 | 05:38 PM
battered_bronco
i have read that the only thing changed from carter to edel AFB was the rubber acc pump and the primary rod was a bottom feed secomndary was the same
do you know what "improvements" were made to the AVS since only the secvondary rod was the same as the AFB
anything even a refer to a carter or god forbid a mopar forum that deal with these things
