Rpm
Old Aug 12, 2004 | 04:36 AM
quickford's Avatar
quickford
Rpm
Want To Know The R.p.m. For 88 Ford7.3 At 65 M.p.h
Old Aug 12, 2004 | 05:18 AM
WhëëlMå1's Avatar
WhëëlMå1
Welcome to FTE. You left out some information. What do you have for tire sizes? How about rear end ratio? What gear are you in @ 65? Do you know that gears overall ratio?
Rich
Old Aug 12, 2004 | 05:35 AM
quickford's Avatar
quickford
Tire size - 16; it's an automatic 3 speed, no overdrive and I don't know rearend ratio. It's an '88 f-250 king cab with a 7.3 diesel.
Old Aug 12, 2004 | 06:33 AM
WhëëlMå1's Avatar
WhëëlMå1
16" tires? Are you sure that isnt your rim size? Also, if you dont know the rear end ratio, there is no way for us to determine the rpm. There should be a small metal tag affixed to the rear diff that has a code on it. With that code, we should be able to figure out what it is (it might also be listed on the sticker in the door jamb).
Rich
Old Aug 12, 2004 | 07:15 AM
Monsta's Avatar
Monsta
Sit. Stay.
Look at the tach.
Old Aug 15, 2004 | 01:52 AM
quickford's Avatar
quickford
Rpm
The Axle Ratio Is 4.10 A Code C-5 Automatic Transmission C6.
Old Aug 15, 2004 | 07:17 AM
Dave Sponaugle's Avatar
Dave Sponaugle
What is known
C6 tranny is 1 to 1 final drive ratio
rear end ratio is 4.1
What is assumed
stock 235/85 - 16 tires are 31" tall
What is calculated
2900 RPM = 65.23 MPH
Old Aug 15, 2004 | 08:53 AM
quickford's Avatar
quickford
thank you, thats exactly what i got! just thought motor was racing too high for 65 mph. thanks again.
Old Aug 15, 2004 | 10:07 AM
edwardldog's Avatar
edwardldog
Rpm
I'm with ya brother. I have an 88 F350 with 7.3 , 4:10 , C6 3spd and the RPM's seem too high. I'm glad you asked that question
Old Aug 15, 2004 | 01:22 PM
fordman428's Avatar
fordman428
im with ya'll to i have an 87 f350 6.9 4 speed, 4:10 gears its at about 2800rpm at 65mph, but it sure does have pulling power.
