4x4 low range gear
Old Aug 11, 2004 | 11:02 PM
jmb1b2b3's Avatar
jmb1b2b3
4x4 low range gear
my low range won't shift in but the high range works fine, does anyone know if i can put in a manual 4x4 shift in from an electric one.
Old Aug 12, 2004 | 05:30 PM
rclarke's Avatar
rclarke
An electric shift transfer case will only shift to 4x4 low if you are completely stopped with your foot on the brake and the transmission in neutral. Be sure you are using the proper procedure.
Old Aug 13, 2004 | 02:58 PM
javi2001's Avatar
javi2001
If trany is auto it shif to Low Range in Park, no matter brake pedal. But be sure the truck is not resting on tranny park to shif in/out Low Range, because electric motor can't move shift fork if it is loaded.
To release park tension, just press brake pedal and hold while move tranny form park to neutral and then back to Park, now shift to Low Range.
