Superlift TruSpeed Sensor
Old Aug 11, 2004 | 09:46 PM
fhartell's Avatar
fhartell
Is anyone using this w/ the 7.3 PSD? If does it work? I'm planning on changing the wheels & tires for a 16" to 18" & the speedo will be off approx. 5mph (65 compared to 60 w/ stock). Thanks for your responses.
Old Aug 12, 2004 | 10:43 PM
Motoxman_117's Avatar
Motoxman_117
Ive had mine for almost 2 years now with no problems and installed it myself. I calibrated it with my GPS and used road side police radar. It is within 1 MPH at 60 MPH. I did the install different than the instructions. The instructions el you to tap into the abs sensor wire by the abs sensor module. I tapped into it in the big wire loom over the front left fender. I have a 2002 7.3L auto crew cab 4x4 with 38 inch tires. Let me know if you have any more questions and i`ll be glad to help out.
Motox
Old Sep 4, 2004 | 10:32 PM
va_f250_man's Avatar
va_f250_man
I'm trying to find my ABS control module on my 99 SD and I'm not really sure where it is. Is it the module right next to the Power distribution module?
