Sloppy gear selector
Old Aug 11, 2004 | 08:46 PM
Phinxter's Avatar
Phinxter
77 F-100 Automatic, my gear selector once put into any gear will move either way about 1/4", obviously something in the column is worn out but what is it and are parts available
Old Aug 11, 2004 | 09:02 PM
Mil1ion's Avatar
Mil1ion
Check the clevis pin on the shift collar.
Is the hole worn into an oval ?
If so that whole shift collar has to be replaced.
Old Aug 11, 2004 | 09:10 PM
Phinxter's Avatar
Phinxter
Huh? Where is that? Do I have to tear the column apart to get to it?
Old Aug 11, 2004 | 09:35 PM
mtandorfer's Avatar
mtandorfer
No...you shouldn't have to tear out the column. Look on the column under the dash for the assembly. It probably has a few wires coming out of it. You will see it move when you move the shifter, that is how you know you have the right thing.
mtandorfer
