pulling truck
Old Aug 11, 2004 | 04:45 PM
charlie calcote's Avatar
charlie calcote
pulling truck
I have a 1999 f350 with 7.3 and auto trans. My question is, will I damage the transmission by pulling the truck about 20 miles to have the starting problem fixed?
Thanks,
Charlie
Old Aug 11, 2004 | 05:33 PM
dieselstroke's Avatar
dieselstroke
no, you'll have to either take out the driveshaft. or unhook the rear of it at the
u joints and tie it up higher than the pinion yoke.(so it doesn't beat up the back
of the driveshaft). Oh & altho u know, i'll say it anyways take out the u-joint
after unhooking the driveshaft. I would do all of this if it were mine, I don't actually
know if 20 miles would hurt the tranny, but i do know on long trips you have to
do this procedure.
Old Aug 11, 2004 | 07:42 PM
Rancha9's Avatar
Rancha9
Is it a 2wd? Tow it with the back wheels off the ground and you won't have to touch the driveshaft...
Old Aug 11, 2004 | 07:56 PM
CAT_man_963's Avatar
CAT_man_963
Or even a 4x4 really - just make sure the hubs are unlocked. If you're gonna flat tow it - I dunno. I think I'd probably go with what Dieselstroke said if it were my truck.
Old Aug 11, 2004 | 08:25 PM
Pikachu's Avatar
Pikachu
Or if you can get it started one time you could leave it idling while you tow it. But if it would start, you wouldn't need to tow it, would you? Ummmm.... Nevermind.
