Noisy Speedometer
Old Aug 10, 2004 | 06:08 PM
Little Bro's Avatar
Little Bro
Noisy Speedometer
The speedo in my '88 Club Wagon has an annoying cyclic noise which sounds like it could be a poorly lubricated speedometer cable. However, I've had the cable greased (twice), and the sound persists. The sound is a combination of tic-tic and scratch-scratch. I can see a little irregular movement in the speedo needle.
Is there a lubrication or other simple solution to this problem? Is the instrument cluster easily accessible?
Old Aug 11, 2004 | 02:01 PM
walkinez's Avatar
walkinez
Wonder if the plastic driven gear in the trans. is bad? (chipped)
There's just a few screws holding the instrument cluster on. After you take them out you can get it out far enough to disconnect the speedo cable from the rear of the panel.
Cheers, Bob
