Items to discard
Old Aug 10, 2004 | 05:06 PM
meangenejr's Avatar
meangenejr
Question Items to discard
I placed this request for info on another forum but there doesn't seem to be much traffic on the site so I'll try here.
Can I assume that the Dashpot is not necessary if you are running a manual choke set-up? Is the Throttle Solenoid necessary if you don't have air conditioning? I'm trying to eliminate as much as possible but retain emissions parts. The previous owner really screwed up the vacuum lines.
Does the ported vacuum switch have a dedicated source port or does it matter? Does the switch source come from above or below the throttle plate?
These questions may sound a little simple to many of you but I have to learn some way. Any help in these areas will be gladly recieved.
Gene Johnson
P.S. Refering to 1981 F100 Ranger W/IL600, 1 bbl Carter
