4 inch lift
Old Aug 10, 2004 | 04:11 PM
spanky1071's Avatar
spanky1071
4 inch lift
I bought a 4 inch lift kit from e-bay. It had some instructions but not any for installing the rear blocks. Does the tapper go toward the front or the rear of the truck?. Any help thanks.
Old Aug 10, 2004 | 07:22 PM
Lou Braun's Avatar
Lou Braun
You want to install the thin side of the tapered blocks toward the front of the truck. This rotates the rear axle just a bit so that the rear end's pinion is slightly raised and helps compensate for the lift.
The blocks usually have the center pin locating holes slightly offset to help position the axle in the center of the truck's wheel wells. The position of these holes assume that the thin side of the blocks is forward.
Lou Braun
