Sponsored by: Innova
Door Speakers
Old Aug 10, 2004 | 03:24 PM
kamac's Avatar
kamac
Door Speakers
What brands of 6.5" speakers is everyone using? In my 89, the stock were 5.25, I bought some cheap 6.5's, but they wouldn't fit in the hole. I guess it needs to be a shallow framed speaker. I m just looking for cheap speakers that can be heard over my exhaust and traffic noise, not audiophile quaility.
thanks
Old Aug 10, 2004 | 06:59 PM
drewcoolness99's Avatar
drewcoolness99
i got 6.5" pioneers in mine and they fit fine.
Old Aug 11, 2004 | 05:48 AM
prcrboy's Avatar
prcrboy
I have alpine in mine with no problems.
Old Aug 11, 2004 | 08:22 AM
4 Juvel's Avatar
4 Juvel
Alpine in my truck, MTX in her car, Boston Acoustic in the Jeep. All work well with head unit power. A little dynamat could go a long way with the road noise.
Old Aug 12, 2004 | 06:51 PM
Camille Marquis's Avatar
Camille Marquis
cheap road noise reducer go to lowes find 6" aluminum backed roof seal flashing about 15 bucks covers alot of space it sticks and stays worked on my ranger though summer and winters
Old Aug 17, 2004 | 11:20 PM
Twisted Ranger's Avatar
Twisted Ranger
Pioneer in the Ranger, Memphis in the Protege, Fusion in the Malibu.
Old Sep 3, 2004 | 08:07 PM
tinman67's Avatar
tinman67
Polk Audio db series are awesome!!!
Old Sep 3, 2004 | 08:08 PM
tinman67's Avatar
tinman67
for fit check www.crutchfield.com they can tell you what will fit
Old Sep 3, 2004 | 09:31 PM
fisholot's Avatar
fisholot
I went with Boston's and they sound great
Old Sep 4, 2004 | 07:45 PM
TrueBlue2's Avatar
TrueBlue2
Audiobahn. Highest dB level for your buck. Go to Lowes/Homedepot and look for Peel n seal (its a roofing material) has same aluminum and rubber layers as dynamat xtreme. makes a huge difference.
Old Sep 4, 2004 | 08:33 PM
kontai69's Avatar
kontai69
Actually, Dynamat Xtreme is an iso-butyl composite while Peal n Seal is "rubberized" asphalt.
Before deciding to use Peel and Seal or any other similar roofing material as a cheap alternative, check out this thread...
http://forum.sounddomain.com/forum/u...;f=55;t=033016
The results seem to vary significantly among those who have used it.
Old Sep 4, 2004 | 08:50 PM
TrueBlue2's Avatar
TrueBlue2
Kontai-
Butyl:A synthetic rubber prepared by co-polymerization of isobutylene with a small amount of isoprene (both ingredients are gaseous hydrocarbons).
Now I wasted hours of my time researching the differences between dynamat, dynamat extreme, fatmat, brown bread and so on.
The reason I finally decided to go with peel n seal is that for 90 cents per square foot I get the same 40mils of rubber and aluminum that dynamat provides for $5 per square foot. The only difference being the asphalt based adhesive. With proper application = no problems.
Old Sep 4, 2004 | 09:45 PM
RomerB2's Avatar
RomerB2
I read that whole forum from sounddomain, and all i have to say is go with peel n seel, if it is applied properly, it will work well.
