99 Ford Expedition Ck Engine Light Code P0401
Old Aug 10, 2004 | 01:40 PM
aggiesoonerdad's Avatar
aggiesoonerdad
Any ideas on how the clear a PO401 code?
Old Aug 10, 2004 | 08:00 PM
Opera House Works's Avatar
Opera House Works
If this still has a metal DPFE sensor, replace it. The metal ones have a corrosion nodule that grows and internally presses on the sensor disk often giving this code. The sensor is actually still good and if you drill it apart, you can clean it up. You should be able to disconnect the battery to clear the code.
