Compression results
Old Aug 10, 2004 | 07:25 AM
christaylor's Avatar
christaylor
Compression results
I tried this in the engine forum but did not get much feedback so I thought I would try it here
#1 137psi
#2 145psi
#3 137psi
#4 140psi
#5 135psi
#6 130psi
#7 150psi
#8 140psi
These numbers seemed ok to me I was told not to worry if they were over 100psi. What had me concerned was the diff between #6 & #7. 20 psi seemed like a large diff. The truck is a 95 F150 351 with somewhere around 150K to my best guess. The engine was replaced once the OD has 218,000
Chris
Old Aug 10, 2004 | 08:15 AM
frederic's Avatar
frederic
Those numbers are close enough that with gauge inaccuracy they are fine.
You should see the numbers on my 290K 351 F350 crewcab.
Old Aug 10, 2004 | 08:47 AM
5_labsownus's Avatar
5_labsownus
Those numbers look great! You will not find too many new vehicles with numbers that are better!
Old Aug 10, 2004 | 01:22 PM
christaylor
Great news!! Thanks for the responses
Chris
Old Aug 11, 2004 | 09:04 AM
jimandmandy's Avatar
jimandmandy
The Ford spec is a maximum variation of 25 percent. Your 20psi min/max is only 13 percent. It looks very good to me.
Jim
Old Aug 11, 2004 | 01:19 PM
christaylor
Well I was thinking about selling it but now maybe i will just invest some more into the cosmetics that it needs and keep it awhile.
thanks
Chris
