chip and 10k mod?
Old Aug 9, 2004 | 07:28 PM
7.3 sled's Avatar
7.3 sled
chip and 10k mod?
Can I do both ? Will there be any gains by adding the 10k mod on top of the superchips tuner? Oh yeah I shimmed the fpr that seamed to do alittle! I will wait to do the 10k mod until I get my gauges installed ! Want to put the 10 k on a switch is this doable ?
Old Aug 9, 2004 | 08:43 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You definately can do it. How much difference it makes will depend on what setting the tuner is in. It will make the bottom end stronger in all settings, but might cost you a bit of power at the top end of the highest setting.
Old Aug 9, 2004 | 09:49 PM
7.3 sled's Avatar
7.3 sled
Thanks cookie I will install gauges and aqwire the needed elecrical parts hope radio shack has what I need !
Old Aug 10, 2004 | 11:10 AM
DaBigTow's Avatar
DaBigTow
I just returned from towwing a 34' RV from Indiana to WaState. I had a 1705 tuned to TowSafe and a variant of the 10k mod (I use a switched 10k linear potentiometer with a 4.7k resistor in series) turned on 50%. At lower elevations and minor grades, everything performed well. When I started pulling harder grades, the turbo started oscillating and the engine would cut out momentarily; I shut off the 10k mod & everything returned to normal. If I'd had the control in-cab, I would've played with the level...
Old Aug 11, 2004 | 12:38 AM
7.3 sled's Avatar
7.3 sled
Thanks for the response I will get gauged and try this 10k thing! A.JAY
