460 badly "squeaking"
Old Aug 9, 2004 | 11:05 AM
JIMY's Avatar
JIMY
Angry 460 badly "squeaking"
I have a 1988 Motorhome on the E350 chassis with a 460 and 22K miles. All oils/fluids etc.. have all been changed regularly but All of a sudden I have a very loud and "squeak" from the engine compartment, but I cannot locate source. When I start cold it does not squeak, but when I drive fora awhile, it comes back.
No water is leaking and it does not appear to be the water pump (although could be?) Don't know the last itme the belt was changed or if it is a belt. Noise is very loud and hard to tell where it is coming form. Anyone have a similar issue or can help me trouble shoot this problem? Enginer runs great, does not heat up, no leaks, power is good, just loud noise?
Old Aug 9, 2004 | 12:24 PM
BSHORT's Avatar
BSHORT
Top Answer: 5
Squeek Louder When The Engine Revs? Belts....tighten Them, Change Them. Anyway, Most Likely Belts...
Old Aug 9, 2004 | 05:54 PM
jim henderson's Avatar
jim henderson
You can pull the belts off and run the engine to confirm if the squeek is the belts or a bad bearing in one of the pulleys.
Good Luck,
Jim Henderson
Old Aug 14, 2004 | 12:04 AM
Chiefrider007's Avatar
Chiefrider007
I suspect the AC compressor, that is if there is one. AC compressors will cycle when you turn on the defrost. Make sure everything is off.
