Ford F100 Engine Swap
Also, tag your wires with locaton and put inside a baggie and seal the end where the tag is. Several of mine I painted over the tag. there was some initial angst over what went where.
While my engine was out, I sanded and painted the underhood area. Also a good time to think about speedo cables, and electrical wires that need replacing, and cleaning/painting the frame. Any grommets to be replaced are easy to get to. How's your steering box? I changed mine and it was a snap to get it out without the engine in place.
Clean and paint the replacement engine. For accuracy, see user Earl's gallery. Put on new belts, check the water pump, etc.. Generally anything that yuo might need to do later in the engine bay can be accomplished easier with the engine out and anything on the engine can be done easier if you can put the engine on the stand and change it there.
Good luck. It took me about 3 hours to get containers ready, label and remove the engine. Then it took about 3 weeks to clean, sand and paint everything else. New engine in took about 2 hours including hookup.
Oh yeah, might be a good time to look at your clutch assembley.
You can do it ! BTW, the new engine is doing fine. and as soon as I test drove it the brakes got jealous and the first time I put on brakes, the wheel nearly jumped out of my hand. So today I start a complete brake rebuild, turning drums, new wheel cylinders, lines, MC , hoses, shoes etc. Will evaluate springs and things too .
Take care
Bub
