Throttle Linkage Simplification???
Old Aug 8, 2004 | 06:24 PM
Almost_A_Merc's Avatar
Almost_A_Merc
Has anyone had luck building a simplier throttle linkage for the FE with and Auto? I have a Barry Grant 4 BBL on an Eldbrock StreetMaster. The throttle linkage I removed from the truck for this engine build (back when it had the 2BBL) is worn out and loose. If you have had success at this, do you have a pictures?
Thanks David
